Taping into fuel?
Old Jun 15, 2014 | 08:55 PM
RedRider24V's Avatar
Question Taping into fuel?
Ok, so i found a mechanical gauge on Geno's that comes with an isolator (SSPRO R5607R Fuel Pressure Gauge (0-60 PSI)-Geno's Garage)
Question, should I run a T fitting on the supply line (between the lift pump and vp44) or run a banjo bolt on the test port (return line?) with a snubber? Im assuming the isolator with help with pulses regardless of where i'm taping the fuel from?
Old Jun 18, 2014 | 12:36 PM
jigabop's Avatar
no the isolator will NOT help with pulses. you need a needle valve or snubber regardless.
the isolator is just an overpriced piece of garbage that will go bad in a few years and make you freak out thinking your lift pump is going out because the isolator will start to leak on the anti-freeze side.
run a tapped banjo bolt to the output side of the fuel filter. That's where I ran mine until I got a 150GPH fuel system that completely bypasses the stock fuel filter. now I run it straight to the fuel systems gauge port on the output side of the filter base.
Old Jun 18, 2014 | 04:20 PM
I guess I forgot to mention I have a FASS 150 HD lift pump. Its pushing out too much psi and thats why im getting a mechanical fuel gauge to figure out where im at
Old Jun 24, 2014 | 01:34 PM
jigabop's Avatar
in that case run a t inline or run from the test port. make sure you use a needle valve or snubber though.
if using a needle valve just barely open it a crack... that will stop the pulses.
Old Jun 24, 2014 | 07:04 PM
Awesome. Thats exactly what I bought from Vulcan Performance. Any tips or write ups for hooking up a pressure gauge? Running SS line into the cab and not using an isolator.
Old Jun 25, 2014 | 01:10 PM
jigabop's Avatar
SS line?
I would just use napa airbrake line...
Old Jun 25, 2014 | 05:09 PM
Its a stainless steel braided line kit from Vulcan Performance. Same as a grease gun line but comes with npt adapters
Old Jun 25, 2014 | 05:52 PM
jigabop's Avatar
you don't need all of that... save your money and keep it simple
literally all you need shown there...
but you would use the T fitting instead of the tapped banjo bolt..
Old Jun 25, 2014 | 07:04 PM
Already bought it all... is that the air brake line? Where else can I find that, I dont have a Napa. Does advance auto carry it?
Old Jun 26, 2014 | 06:37 PM
jigabop's Avatar
yes, that is the airbrake line.. rated forover 150psi so the sub 30 psi we run is never getting though that line
Nylon air brake tubing 1/8 x100ft, 1922-01-1, Tectran - Ryder Fleet Products
$16 for 100ft of it there :doh:
little excess when you only need 6' of it..
might check local auto parts stores around you. usually something they have behind the counter...
1/8" air brake line.
