Gov spring kit
Old Jun 10, 2014 | 09:50 PM
gunslingerburkhart's Avatar
Default Gov spring kit
I have a 97 2500, contemplating putting a 4k gsk on it what else would be good to do along with it?
Sent from my Commando
Old Jun 11, 2014 | 09:56 AM
turbo2332's Avatar
install them and enjoy. if your truck actually revs to the 3500rpm range then install heavier valve springs.
Old Jun 12, 2014 | 05:09 PM
Alright thanks
Old Jun 12, 2014 | 06:02 PM
LostSoul71's Avatar
If you are driving an auto, it is most likely going to want to shift at or around 3K, the only advantage to you in an auto that I have seen with the 4K spring is that you know you will have full fuel up to the point the transmission will want to shift, where as the 3K gsk will be out of fuel just before that point. I love the 4k in my manual as it allows me to run a little further into RPM in a lower gear while towing to keep momentum on hills etc.
Old Jun 12, 2014 | 07:03 PM
4x4manonbroke's Avatar
I too will be looking to get 4K's in my truck ... my trans now shifts great, now I can worry about cutting down my Et when it comes racin time ..
Old Jun 12, 2014 | 07:38 PM
I have the 5 speed so the shifting is not a problem. Sounds good..
Old Jun 12, 2014 | 08:46 PM
Lol.. Yeah, wish I had a 6 spd..
Old Jun 14, 2014 | 06:06 AM
JBearSVT's Avatar
I wish that every minute of every day that it isn't snowing. I need to move south...
Old Jun 17, 2014 | 11:08 AM
Isn't the 6th gear in the nv5600 the same ratio as the 5th in the nv4500 ?
Old Jun 17, 2014 | 12:13 PM
no the NV4500 was .75 and the 5600 is .73.. close but a few rpm's different
