Rough running/ code 0279
Old Jun 10, 2014 | 07:47 AM
johnking's Avatar
Default Rough running/ code 0279
Out of nowhere the truck is running crazy rough(1996 F350 4 door 4wd). Auto eng scanner give 0279 code/ #7 inject voltage low on buzz test. Female valve cover harness plug on passenger side closest to bumper is missing a fin and the corresponding male part looks fractured/melted. I am assuming this is my problem. Do you folks agree? How hard is the fix? Anything else that I should look for. I am not the most experienced mechanic but I was able to change my fuel pump.
Old Jun 10, 2014 | 08:26 AM
joebob3093's Avatar
Moderator
Replace the uvch, its as hard as taking off the valve cover
Old Jun 10, 2014 | 10:46 AM
johnking's Avatar
Ordering parts now. Will I need a new gasket?
Old Jun 10, 2014 | 07:32 PM
joebob3093's Avatar
Moderator
It couldn't hurt, but if it doesn't look bad I might be fine
Old Jun 16, 2014 | 07:18 AM
johnking's Avatar
I should have looked before I ordered parts. I took off the cover and I will need a gasket also. Riffraff was super quick with the harnesses and now I will order the gasket. The uvch was melted and the some of the pins in the gasket were melted/missing as were the male.
Old Jun 30, 2014 | 07:12 AM
johnking's Avatar
Got it done. Getting the VC back on was tough. Getting the bolts back in was a lot more difficult than I though it would be, especially at the dip stick holder.
ssmith.77
Nov 25, 2018 06:56 AM
ssmith.77
Jan 11, 2015 02:03 PM
f250white
Jan 11, 2015 09:25 AM
Fishy816
Jan 11, 2015 08:31 AM
bizurkhate
11
Nov 14, 2014 12:15 AM
