fuel problems
Old Jun 5, 2014 | 06:55 PM
tdm's Avatar
tdm
Default fuel problems
i have a 95 powerstroke it will not start by just turning the key.It seems the truck is not getting any fuel. If you spray a shot of starting fluid it starts up runs and drives no problem but cut it off and then try to start right back nothing.
Old Jun 6, 2014 | 12:17 AM
joebob3093's Avatar
Moderator
Never use ether unless you want to replace head gaskets, is the oil full and have you scanned it?
Old Jun 6, 2014 | 08:07 PM
tdm's Avatar
tdm
The oil is full. I've not had it scanned yet but there's no lights on. Today it gained another problem ever time i pushed the clutch in to change gears it would die but would restart by rolling it off. And at idle it sounds like it had a miss the rpm gauge doesn't move though like it's missing.
Old Jun 6, 2014 | 08:44 PM
joebob3093's Avatar
Moderator
Scan it, the light doesn't need to be on to have codes
gillespie3033
Chevy/GMC Duramax 01-04 LB7
29
Jun 25, 2015 03:51 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
J. Nick
Apr 24, 2015 01:13 PM
moneypitk5
Feb 12, 2015 11:01 AM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
