mexican need help
Old Apr 30, 2014 | 03:53 PM
siryame's Avatar
Default mexican need help
hi partners i got a big problem, my chevy is not runing good some times does a long crank and when starts it runs really bad, stumbles an dies has crank sensor changed and pump cam sensor changed, now showing 18, 19, 35, 54 & 65 codes ani help?
Old Apr 30, 2014 | 09:35 PM
RedChevy44's Avatar
Welcome!
Old Apr 30, 2014 | 10:05 PM
siryame's Avatar
Thanks Redchevy44
Old May 9, 2014 | 04:43 PM
racer55's Avatar
Crank sensor must be AC Delco ONLY!
All others are bad right out of the box.
Optical sensor is very delicate and must be put back in the exact same position as it was removed-otherwise it will cause a big headache and might require that the IP be put back on a calibration stand to correct it?
It can be repositioned through trial and error if patient though?
