Dodge Diesel Tech Articles All Years of Cummins Tech Talk
Headlight/Clearance/Turnsignal Lamp Change-How To
Old Apr 27, 2008 | 03:58 PM
wildbill's Avatar
Default Headlight/Clearance/Turnsignal Lamp Change-How To
For future/current owners, or who knows someone that owns an 03-cur. Dodge Ram 1500-3500, and has one or more of the lamps burn out, here's how to change them out.
Tools needed:
3/8" ratchet w/ a 6" wobble head ex. & reg. 3" ex., 10mm deep & shallow sockets, & a medium sized screwdriver.
Part(s) needed: 1-2 H13 lamps.
Remove the rubber access plug (located inside of front fender well) ,use the 6" wobble head extension and deep 10mm socket to remove the nut.
Remove the two bolts w/ the 3" ex. and shallow 10mm socket.
Pull out assembly.
Headlamp is the green plug, turn signal is the light pink plug, and the clearance lamp is the white plug. Slide the red tab up, squeeze the release and remove connector.
Remove old lamp, install new one(make sure you don't touch the glass end. Oil from your fingers will cause a hot spot on bulb and shorten life of lamp), then reverse procedure.
Side note: This was done on an 06 and the headlamp was an H13, the 05's and older were a different bulb. Procedure will be the same for the clearance and turn signal lamps.
Old Apr 27, 2008 | 08:32 PM
Nice info...
wlofton
11
Jun 26, 2018 08:58 AM
nomoney
Jun 16, 2015 08:16 AM
ctjkelley
Jun 3, 2015 06:01 AM
crusty
5.9L CR Performance
Apr 26, 2015 03:31 PM
Bigredpowerstroke
Dec 19, 2014 05:18 PM
