now it willnot start
Old Apr 26, 2014 | 11:51 AM
KDRowand's Avatar
Default now it willnot start
I have a 1991 7.3 IDI and it was running but kind of rough, real hard to start. I pulled all the injectors, to clean them out, one at a time so I would not get them mixed up going back in. My return rail was leaking real bad so I also got a rebuild kit for the rail now no leaks, but no start. I tested the glow plugs and found 3 bad plugs, replaced all 8, now plug light stays on 10 seconds like it should but it took about 3 weeks to change plugs and clean injectors so I think I have a air lock somewhere and I cannot find it. I got the truck to pay a debt so I only know some of the history - farm truck, bought at auction for another farm, given to farm hand in place of pay (he knew NOTHING about diesels), gave it to me to pay a debt ran OK for 3 years. Fuel Pickup in one tank is broken at 1/4 of tank seems to be a common problem in old IDI trucks. Second tank is OK and has more than 3/4 fuel, still seems like I am starving for fuel. What next?
Old Apr 26, 2014 | 01:55 PM
PJR's Avatar
PJR
If it has a mechanical lift pump did you replace that?
Old Apr 27, 2014 | 03:12 PM
KDRowand's Avatar
I did not replace the lift pump, I took the filter to IP line off and cranked the engine and got plenty of fuel out lift pump works!!!!
Old Apr 27, 2014 | 03:15 PM
BBD Tech Support's Avatar
Old Apr 28, 2014 | 09:44 AM
PJR's Avatar
PJR
My father in law and brother in law each had a couple of old Fords about that age and I know they were forever having trouble with the injection pumps. Between that and glow plugs I think they got tired of them. Good Luck.
Old May 20, 2014 | 09:29 PM
4x4manonbroke's Avatar
Anything so far ?
Old May 21, 2014 | 03:25 PM
Sycostang67's Avatar
How long have you been trying to start it? Replacing the injectors and return lines will allow a lot of air into the fuel system and will take some time to get it fired back up again.
Old May 21, 2014 | 11:55 PM
I usually prime mine with ATF , usually fires right up , of course i have my foot to the floor too ... never dies , close a few times ..LOL, then takes right off !!!!
Cavnar
Sep 9, 2015 07:18 PM
cjgregory
Mar 31, 2015 01:45 PM
IGOU
Mar 8, 2015 04:25 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
