low fuel pressure
Old Apr 18, 2014 | 06:59 PM
burnhedge's Avatar
Default low fuel pressure
95 dodge all stock. I've had problems with this truck running rough and blowing white smoke when starting up cold. Put a new LP on awhile back and no change. I've pressurized the tank several times and looked for leaks...nothing.
Got a fuel pressure gauge put on today and pressure seems to be low. Holding 13 psi at idle. 20 at 2500rpm. On the highway it drops to 10 when I put my foot down.
Could something be restricting flow? (F
(Filter is new)
Old Apr 18, 2014 | 07:01 PM
4x4manonbroke's Avatar
timing issue ..
Old Apr 18, 2014 | 08:28 PM
JBearSVT's Avatar
^ What he said. A 1995, all stock, chances are extremely good that the pump timing has never been messed with and has probably slipped. It will do that, and it doesn't take two decades... so I bet you're probably 3-4 degrees low at this point. It can eventually slip so low that it'll barely run. It only takes a few minutes for someone who knows how to do it to check it and see if it's where it belongs. Not that it hurts to check the flow culprits yourself: how old is the fuel filter? The pre-filter screen in the fuel heater can also get pretty full of crap if it isn't popped out every now and then.
Old Apr 18, 2014 | 08:47 PM
mysterync's Avatar
Seems pretty low fuel pressure wise. Overflow valve ok?
Sent from my SCH-I605 using Tapatalk 2
Old Apr 18, 2014 | 09:42 PM
dieseldemon61's Avatar
I was kinda thinking the overflow valve too, especially if its the original.
Old Apr 19, 2014 | 08:23 AM
turbo2332's Avatar
ofv all the way.
Old Apr 19, 2014 | 11:36 AM
burnhedge's Avatar
Yea I pinched the return line this morning and my pressure jumped to 30. It has a tork tech adjustable valve on it. The plug seemed extremely loose. I could turn it with my fingers.
I turned it down a little bit now getting 20 psi at idle. Only 25 at 2500rpm. Didn't seem to help the cutting out and white smoke. I'm going to order a new valve and if I can find someone to check my timing.
Any recommendations on the ofv I should get? Brand? Adjustable?
Old Apr 19, 2014 | 11:58 AM
mysterync's Avatar
Truck still have a fuel heater?
I'd crank the fuel pressure on up and leave that ofv in place.
Old Apr 19, 2014 | 12:40 PM
turbo2332's Avatar
[QUOTE=burnhedge;1058386]
QUOTE]
i will be in KS in about a month. you got tools? LOL
Old Apr 19, 2014 | 01:44 PM
Don't crank the ofv to much ... You will damage the IP if the flow isn't enough to cool he pump ...
