Axle Seal
Old Apr 16, 2014 | 11:20 PM
IHdude's Avatar
Default Axle Seal
Hello Everyone, I have a leak coming from my front axle on my drivers side and was wondering if anyone could explain what all is involved with replacing that seal and if there is anything special needed.
Thanks for any help.
Old Apr 17, 2014 | 10:07 PM
six speed's Avatar
take the tire off, then the brake caliper, then the hub assy., and pull the axle shaft out. this is as far in as i have been. the seal is on the inner end of the axle tube so i believe you have to pull everything off the other side as well then the diff cover, the carrier,and then you can pull the seal out through the differential. i could be wrong as i've never had to do this but it is the only way i can see to get it out.
Old Apr 17, 2014 | 11:32 PM
IHdude's Avatar
Alright I was afraid about that with having to go through the differential and removing everything. Thanks for your help!
Old Apr 18, 2014 | 03:38 PM
4x4manonbroke's Avatar
You do not need to disassemble the diff .....
I typically pull the knuckle, then u can use a seal puller and it will come out .... Also by pulling the knuckle, its much easier to install the new seal once your all cleaned up and ready to install ...
Old Apr 18, 2014 | 05:55 PM
sweetv8s10's Avatar
How do you take the seal out and put it back in from the outside if its an inner axle seal? All of them that I have ever seen you have to pull the carrier to change it. If it was the passenger side with the vacuum pod then you wouldn't have to remove the carrier.
Old Apr 18, 2014 | 06:59 PM
Ahhh ... true ... good point ... had not even considered that part ....
I think I was thinking IFS again .... oops
Old Apr 19, 2014 | 08:59 AM
rdsutton's Avatar
Inner axel seals are tough. the extractor, installer tool a little $$. took mine to axel shop. Seals & labor $200.00. Well worth it.
Old Apr 19, 2014 | 11:33 AM
IHdude's Avatar
Thanks for the input guys! I need a some alignment work done so I'll have that added on.
Old Apr 19, 2014 | 01:45 PM
Might as well get it all done in one swipe
Old Apr 19, 2014 | 11:23 PM
sweetv8s10's Avatar
Once you get the carrier out just remove the old seal and its been a while since I have done one but I think when you put the new seal in you can use a socket that's the same size and you should be able to tap it in but I not 100 percent sure.
