Adjusting fuel pressure
Old Apr 10, 2014 | 12:58 PM
99ppumped24's Avatar
Default Adjusting fuel pressure
I pumped my 24v and I had a Fass Titanium 150 on it. Is there a way to adjust the pressure or do I have to get a new pump?
Old Apr 10, 2014 | 07:33 PM
4x4manonbroke's Avatar
how much FP do you have now ??
Old Apr 10, 2014 | 11:49 PM
Diesel Duo's Avatar
Restriction vs flow rate
Two different things remember. If line size is increased then pressure will drop but flow remains constant.
Not saying that is the case. It is just something to keep in mind.
DD
Old Apr 11, 2014 | 09:10 AM
About 17
Old Apr 11, 2014 | 05:32 PM
turbo2332's Avatar
is it the FASS for the 24 valve? if so yes it cant make enough pressure to feed the inline pump. you need to be in the 30-50 range 17psi will kill the inline
Old Apr 11, 2014 | 06:22 PM
Originally Posted by 99ppumped24
About 17
Oh dang ... yeah ... that was way to low ....
Old Apr 11, 2014 | 09:15 PM
turbo2332's Avatar
i dont think you will be able to adjust it high enough for what you need . you will be able to get it to start and run and idle around but i do not believe you will be able to use the truck with that pump.
Old Apr 12, 2014 | 12:16 AM
I think a tork tek adjustable return .... wouldnt that help ??
Old Apr 12, 2014 | 07:56 AM
turbo2332's Avatar
no
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
