EGT going crazy NEED HELP
Old Apr 5, 2014 | 08:01 PM
asd1211's Avatar
Default EGT going crazy NEED HELP
I have a 97 12 valve cummins 4x4 with an auto trans. I have the starwheel adjusted but i lost my place. The only egt trouble i have is on the freeway hauling a load at high rpm and boost. The afc housing is all the way forward and the fuel plate is all the way forward. if i back the fuel plate off a bit will it help get my egt's under control? Thanks
Old Apr 7, 2014 | 12:57 AM
97cummins's Avatar
Yes it will,you should back off the star wheel a little also.
You should fill out your signature to let us know better what mods you've done to the truck.
And I would recommend an egt gauge if you don't have one installed yet.
kevin krehel
18
May 14, 2015 05:07 PM
Brappp306
Mar 29, 2015 08:54 PM
bonestock
Feb 1, 2015 08:41 PM
tbreddiesel
Thoroughbred Diesel
Oct 14, 2014 07:44 AM
