95 2500 Front suspension
Old Apr 4, 2014 | 06:00 AM
brn2skifst's Avatar
Default 95 2500 Front suspension
My 95 2500 has about 91,000 mi on it and the front end has a lot of play. I have new Cooper AT's (E range) at 50 PSI front. It runs pretty straight but seems to understeer (dives) more when turning right than left and there is a vagueness in the steering when running straight. (I have to move the steering wheel quite a bit left or right before the tires respond). Is the vagueness normal? I would assume shocks for the understeer problem. Any thoughts would be helpful. Thanks.
Old Apr 4, 2014 | 11:55 AM
Mase's Avatar
It's time for upper and lower balljoints,tie rods,pitman arm,idler arm,idler arm control arm.
Old Apr 5, 2014 | 10:50 AM
Repomatt's Avatar
Jack the truck up and look for play in your front end components. You may also have some play in the steering box
Old Apr 6, 2014 | 05:35 PM
Mayhem's Avatar
you do need more air pressure in them tires 65-70 minimum
Old Apr 7, 2014 | 06:35 PM
94 Double"D"'s Avatar
I agree you definitely got a issue with one or most of those components.
shingi
Off Roading
Sep 30, 2015 11:17 AM
carid
Diesel Bombers Sponsors
Apr 22, 2015 09:28 AM
dieselpowa
Jan 26, 2015 03:02 PM
Dec 29, 2014 10:20 AM
