fuel pressure regulator
Old Apr 3, 2014 | 08:09 PM
jle70's Avatar
Default fuel pressure regulator
Looking for fuel pressure regulator. Can't seem to find one without buying whole filter assembly.
Old Apr 4, 2014 | 05:34 AM
MAFoElffen's Avatar
What was wrong with your existing fbr? You know they are rebuildable right?
If a broken housing (it happens), then I'd look in a wrecking yard or a used fuel bowl on ebay... remember, I said they are rebuildable?
Old Apr 4, 2014 | 06:04 AM
jle70's Avatar
Cracked.
Old Apr 4, 2014 | 09:25 AM
joebob3093's Avatar
Moderator
I JB welded my stock regulator. It held great for a couple years. I even sold it and the guy ran it just as it was
Old Apr 4, 2014 | 03:24 PM
jle70's Avatar
It is cracked at the high pressure fitting. JB will hold there?
Old Apr 4, 2014 | 06:46 PM
joebob3093's Avatar
Moderator
doesnt hurt to try, clean it and dry it really well then JB weld it
Old Apr 16, 2014 | 03:51 PM
dieselboost14's Avatar
Hello Im new to forums, and well I've been having problems with 1995 7.3 Powerstroke i have been having a bad leak! its leaking from where the starter is mounted on. There's no fuel in the valley. Ive also noticed that my fuel drain valve dosnt drain when i open the valve . NEEEEEDDDD HELLPP Please
When i open the drain valve it wont exit the fuel from the bowl
Last edited by dieselboost14; Apr 16, 2014 at 03:51 PM. Reason: Automerged Doublepost
Old Apr 16, 2014 | 05:48 PM
joebob3093's Avatar
Moderator
How many places are you going to post this? One place is good enough, don't need to fill up other peoples threads with your problems
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
19Samahi72
Chevy/GMC Duramax 01-04 LB7
Jan 26, 2015 10:55 AM
