truck will not stay running after big line kit
Old Mar 30, 2014 | 03:40 PM
ebarresi5894's Avatar
Default truck will not stay running after big line kit
Ok so I have a 97 12v with a 1/2" kit from the sender up to the IP. could not get it to run the other day and finally it fired up, would run for about 10 mins then die. Start back up run for about 5 mins and die.
Today I figured ok ill double check all the connections and see what happens. Went to start it, would barely fire over and finally started but I had to keep my foot on it. Now it wont idle. If it does it will for about 3 secs and shut off.
Now everything worked fine until I put this kit on.
The only thing I can think of that could be the problem is either:
I never used a bigger return line.
or
there is a float at the bottom of the strainer of my sender, I never took that out with the drawstraw. Could this be blocking flow?
Any input is appreciated
Old Mar 30, 2014 | 06:14 PM
4x4manonbroke's Avatar
bump your fuel pressure ... its return line pressure isnt enough and its emptying the IP ... hence the not running .. pinch your new return line just a bit with a pair of plieres and see if when you let go if it dies .... if it does ... you have your problem
Old Mar 30, 2014 | 06:22 PM
Ok thanks! ill try that tomorrow. If it does die, should I use a bigger return line?
Old Mar 30, 2014 | 06:26 PM
smaller .. or get a tork tec ajustable return line kit ... i think your pump is not keeping enough fuel in the pump to keep it running ...
Old Mar 31, 2014 | 10:13 AM
Ok thanks ill try the pliers tommorrow. Now even though I went with 1/2 lines it wont keep enough fuel in the pump?
Couldn't even get it to start today. Overnighted an adjustable ofv and see if thst helps.
Last edited by ebarresi5894; Mar 31, 2014 at 10:13 AM. Reason: Automerged Doublepost
Old Mar 31, 2014 | 03:08 PM
Good idea ...
Old Apr 2, 2014 | 04:58 PM
Ok so I put the ofv in, got it started runs awesome. Took it down tge street got it going good and parked it for about 5 mins. When I go to start it now I always have to give it a little pedal to get going, then it idled and ran perfect.
Old Apr 2, 2014 | 11:16 PM
adjust the idle ... ... again ...
Old Apr 3, 2014 | 09:35 AM
It idles at 800. Its almost like it is hesitant to start and starts missing for 3 secs and clears out
Old Apr 3, 2014 | 03:11 PM
Air intrusion .... Delete fuel heater from lift pump ... They leak ... Mine does it too ... Another thing to fix when I do my HG...
