glow plug controller
Old Mar 20, 2014 | 08:15 PM
jeremy d's Avatar
Default glow plug controller
After giving up on a manual relay, I installed the brand new controller and relay. Now it just clicks off and on off and on. Its wired correctly. All plugs are new and testing good. No interruption between the relay and plugs. What could be causing it to click off and on?
Old Mar 20, 2014 | 11:05 PM
powerstrokin350's Avatar
Does it stay on first, and then start clicking after 15 seconds if so? Some of I know my system burns the GP for 15sec and then cycles them on and of for about another 15sec.
Old Mar 21, 2014 | 05:29 AM
jeremy d's Avatar
As soon as the key turns
Old Mar 21, 2014 | 12:14 PM
Does your system have the water temp sensor that tells the system when your truck is already warm and doesn't need GP function? Maybe that or bad ground?
Old Mar 21, 2014 | 08:16 PM
jeremy d's Avatar
Its got the sensor. The controller is working now but I still can't get it to start with the gp. Once warm it fires right up. Good compression. Should the big wire where the green wire hooks to have power when controller is energized?
Old Mar 22, 2014 | 01:56 PM
Dortiz's Avatar
Metz1234
Mar 3, 2016 10:20 PM
1997silverado
Mar 12, 2015 11:11 PM
Texasthb
Mar 4, 2015 08:20 AM
ajwright64
Feb 4, 2015 09:36 PM
norcal6.5
Dec 7, 2014 07:04 PM
