number 9 resistor
Old Mar 16, 2014 | 04:23 PM
timberfaller's Avatar
Default number 9 resistor
finally had time to install a number 9 resistor in my PDM "I bought the best one NAPA had it has alife time warrenty on it" I added an a extra ground wire from it to to the ground wire on the block thought it might need one since I had reloacated it to the bumper. I had been driving it for about 6 k miles with out a resistor in it ran fine .. three days latter my 1994 6.5 154k miles on it dies.. take the resistor out start right up.. dies again.. now it acts like it want to start but not getting enuff fuel.. once I thought i might have flooded it ?.. it did start once but died just like you turned the key off.. I ran the batterys down and been charging and charging them up back up.. been reading a lot of the post ... you guys are great help.
WOW ... Just moved the PDM back to the factory plug in ... started right up bad harness???.. I will go check it again..
wont start again acts like it wants to but only smokes... if it was gas its like its fireing on 5 cly..
Last edited by timberfaller; Mar 16, 2014 at 04:23 PM. Reason: Automerged Doublepost
RatsMC
May 4, 2015 05:25 PM
countryboy040993
10
Nov 16, 2014 08:21 PM
