Cummins won't start
Old Mar 12, 2014 | 06:54 AM
Alexandersdiesel's Avatar
Default Cummins won't start
I have a 1998 12 valve cummins all stock all I did was repair front seal leak and the KDP while in there I replaced water pump truck sat 2 weeks and now will not fire except with ether. I have now replaced fuel filter, the rpm sensor at harmonic balancer, bled injectors the solenoid is working fine and have plugged it into a code reader and there is nothing it all checks out! I need some help anyone have any ideas? This truck has never givin me any grief at all it ran awesome!
Old Mar 12, 2014 | 07:36 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
sounds like you still need to bleed the injectors.
Old Mar 12, 2014 | 10:23 PM
I have done it a couple of times but I feel like there isn't enough fuel there but there is fuel there and still not fire I have been doing some reading and says I should have 18-24 lbs pressure now will it be there while trying to fire and where would I put a fuel pressure gauge? I really need to figure this out so any idea would be appreciated a lot!
Rusher48
Jul 2, 2020 08:39 AM
mcclusk
Feb 21, 2015 09:50 PM
Rusher48
Feb 20, 2015 05:19 PM
rschriek
Jan 26, 2015 07:30 AM
Downd19
Dec 30, 2014 02:49 PM
