94 F250 Pre power stroke will not rev
Old Mar 10, 2014 | 07:35 PM
DK1981's Avatar
Default 94 F250 Pre power stroke will not rev
My 94 F250 Direct injection Turbo diesel will not Rev up at all, it smokes like its getting way to much fuel? I am lost here, I just put a new Map sensor on because my tuner gave me the code indicating that it was bad. Still doing the same thing. Any ideas?
Old Mar 10, 2014 | 08:28 PM
joebob3093's Avatar
Moderator
If its direct injection its a powerstroke. Do you have a scanner?
Old Mar 10, 2014 | 08:41 PM
DK1981's Avatar
Its the international, i don't have scanner that works for my year, I have a programmer that runs diagnostics, but it showed the map sensor was bad, I replaced it, but still no change
Old Mar 10, 2014 | 09:48 PM
SinnerRacing52's Avatar
The powerstroke is an international engine. Is it an idi as in indirect injection or the powerstroke which is a direct injection engine.
Old Mar 11, 2014 | 07:01 AM
DK1981's Avatar
Default Direct injection
My truck is definitely direct injection, F vin, if that helps anyone out!
Old Mar 13, 2014 | 11:12 PM
79jasper's Avatar
If it's smoking white, and smells like fuel, most likely a fuel problem.
Maybe clogged filter, line, etc.
If it's black, you're getting too much fuel for the air available.
Could be a severely clogged filter, bad turbo, etc.
You may try seeing what it does if you unplug the icp sensor.
All set the truck back to stock and remove the programmer.
Dec 10, 2014 08:10 AM
Oct 13, 2014 08:10 AM
