Need tranny advice asap please!
Old Mar 6, 2014 | 07:01 PM
Gncc23's Avatar
Default Need tranny advice asap please!
Should I just buy a built torque covertor or built TC and trans...and what brand/kind?
So here is my problem. I have a stock trans and torque covertor. Its starting shift kind of rough and when it gets hot from driving a while it starts to feel like your slighly pressing a clutch in when pulling out from a dead stop (slipping) and starts to feel like there is play if you brake then accelerate (like something is slideing forward then backwards.
It is a 03 silverado 2500hd, 4wd, automatic. Efi live (5 tunes; 150 and 80hp are my most used) 4" straight exhaust, afe cold air, ppe boost valve. 200k miles.
Old Mar 7, 2014 | 04:21 AM
97cummins's Avatar
You could get a built torque convertor, i think that may be one of the reasons for the trans. slipping.
You should also think about upgrading your valve body.
I had a triple disc and heavy duty valve body put in my truck last year and it shifts better than before. As for good companies out there, there are a lot of good ones. Mine is from source automotive near Portland Oregon.
Hope this helps.
Old Mar 7, 2014 | 10:19 PM
2004LB7's Avatar
for starters, you should look into changing the transmission fluid and filter. this may help a lot
peterbilt
Chevy/GMC Duramax 06-07 LBZ
Apr 8, 2015 10:33 AM
twm011
Feb 24, 2015 09:11 AM
wilki
Feb 12, 2015 09:04 AM
Ol Goat
Jan 22, 2015 02:16 AM
Ol' RED!
Dec 11, 2014 10:00 AM
