auto trans help I'm looking to upgrade my converter and valve body?
Old Mar 6, 2014 | 05:29 AM
lms1977's Avatar
Default auto trans help I'm looking to upgrade my converter and valve body?
Sorry I just saw that the other thread I posted this in was wrong so I copied it over to here.
I have a 96 2wd auto truck everything works great truck has 190k on it shifts great etc and is 100% stock ..
my question is I tow our camper and or atv's around 5000#'s or less I'm sure. The truck is kinda doggy in the mountains where we ride going thru towns and what not, seems that the converter stall is just a little to high for my liking when towing??
I am thinking of putting a converter in it but don't want to put a super high dollar one made for big hp and tq seems like a waste of money to me?? I also would like to mod the valve body with what ever parts are needed/recommended for my type of driving or power.
possibly I will rebuild the trans but not sure if this is necessary beings it works great and does not seem to slip.
when I got the truck at 170K from the original owner (relative) he had never as much as changed the trans fluid even once or adj the bands
so I did that and the bands did not seem to need much at all I was surprised..
my honest plans are with the truck is to keep the oem air box and a stock exhaust or atleast something quiet so it is nice when the family and I use it, I would like to possible bump the power a touch maybe a #12 plate or just slide the stock one forward?? a 3k spring or adjust the stock one? and do the timing.
I don't want a loud truck or one that smokes just a good truck for towing and using for family vacations I think the truck makes 420 ft lbs tq stock? I would think 500 ft lbs tq and a better converter would be a awesome all around truck?
I'm not sure if I'm on the right track here? any advise would be appreciated
basically I'm looking for what is actually needed not looking to build a drag truck I also drive extremely conservative hence probably why the trans is still running
ok sorry for the long book here if you guys can steer me in the right direction that would be great.. mainly looking to beef up the tranny before I do anything, to the truck it might not need more power once the converter puts the power to the wheels?? but want to build it to accept a extra 80 ft lbs of tq if im going to buy a converter
thanks Mike
Old Mar 7, 2014 | 04:57 AM
97cummins's Avatar
You are on the right track. A good heavy duty double disc torque convertor and valve body will do wonders for you. I had a triple disc and heavy duty valve body put in mine last year and wow.
You can also do some adjustments to the fuel pump to help with the towing,fuel ecomomy, ect.
Another question for you. Is your killer dowel pin dealt with?
Old Mar 7, 2014 | 07:02 AM
lms1977's Avatar
I was just reading about the kdp earlier I guess that is something else I need to look at and address
