Heat randomly stopped working
Old Feb 26, 2014 | 10:49 AM
nharroll's Avatar
Default Heat randomly stopped working
I'm new to the Duramax. I recently bought an LB7 and everything worked great! I've made a few little changes and I had no complaints until last night. My heat decided to start blowing out cold air. I checked all my hoses and they were all warm after a little drive, engine temp gauge is still working which tells me it couldn't be the thermostat, I pulled an HVAC fuse to see what happened and still no change. Can someone help me please? It's snowing outside and I'm not in the mood to have no heat.
Old Feb 26, 2014 | 01:51 PM
Walker.B's Avatar
i just had a buddys LLY do the same thing put two new thermostats in as good as new
Old Feb 26, 2014 | 09:01 PM
nharroll's Avatar
Thanks for the reply! I'll give it and see what happens. If it doesn't work you'll be hearing from me pretty soon haha.
Old Feb 27, 2014 | 08:18 PM
Walker.B's Avatar
good luck man heres what we used on my LB7
Merchant Automotive - Thermostat- Front Duramax 185 degree
Merchant Automotive - Thermostat - Rear Duramax 180 degree
Merchant Automotive - Thermostat Housing Gasket
JPT18
Mar 6, 2016 11:20 AM
InheritedDiesel
Oct 26, 2015 10:24 AM
Aug 10, 2015 06:40 PM
auspot
Jun 30, 2015 05:57 AM
Low_Life_Style
16
Nov 29, 2014 06:28 PM
