ticking sound help
Old Feb 23, 2014 | 03:32 PM
patpat paul's Avatar
Default ticking sound help
i have a 98 12v with a killer bee super and bd 3 piece exhaust manifold i have had this sound before i put new parts on sounds like an exhaust leak but only makes this ticking air loss sound under boost i put new air to air boots on checked all clamps reseated injectors and replaced the line between intake and injector pump driving me nuts anyone have any ideas to find this leak? kinda sounds like when wasegate relieves extra boost i am running about 35-37 lbs
Old Feb 23, 2014 | 11:59 PM
12vcumminspower7's Avatar
Black smoke or hardly any?
Old Feb 24, 2014 | 12:09 AM
191 delivery valves lots of smoke
Old Feb 24, 2014 | 09:57 PM
Im talking since you discovered the tick?My guess is either low fuel pressure to IP ot bad overflow valve?Or bad lift pump if you have stock lift pump?Check your fuel pressure
Old Feb 25, 2014 | 12:10 AM
eeyore's Avatar
If you have a clean shop vac. I REALLY MEAN CLEAN , you don't won't to blow dirt into your engine. But fix it to blow and tape it to your exhaust and use some soap in a spray bottle and check for bubbles. Again a clean shop vac even a clean hose.
Old Feb 25, 2014 | 04:42 PM
JBearSVT's Avatar
My lift pump ticks. It's the original. Kinda loud, sort of pisses me off. Been doing it for about, oh, 120K now...
Old Feb 25, 2014 | 05:34 PM
It's because its mechanical but the ticking can get very aggressive when she's on her way out but some might not.
Old Feb 25, 2014 | 06:05 PM
JBearSVT's Avatar
Well, it's still pushing 30psi or more cruising around, 25+ ***** to the wall, 22-25 at idle, so, not too worried yet. I've been saying that for two years now though, so...
Old Feb 25, 2014 | 06:13 PM
Trust me,you will know when she goes!One day your truck could be rabbit on coke next day a crippled turtle!
Old Feb 26, 2014 | 05:00 AM
JBearSVT's Avatar
So what you're saying is, I should put a new one in my toolbox and hope the sun is shining when I need it?
