F250 Cummins Swap
Old Feb 17, 2014 | 07:08 PM
claybreaker 144's Avatar
Default F250 Cummins Swap
[IMG]<a href="http://s13.photobucket.com/user/slezatcndg/media/DSCN3319_zpsa8cd8baf.jpg.html" target="_blank"><img src="http://i13.photobucket.com/albums/a265/slezatcndg/DSCN3319_zpsa8cd8baf.jpg" border="0" alt=" photo DSCN3319_zpsa8cd8baf.jpg"/></a>[/IMG]
Putting a 12V into my 04 F250
NV4500
NP271 Changed input shaft
Diesel Conversion motor mounts
Moved the motor all the way to the rear of the motor mount slot and rear driveshaft is going to be 3" short. Talked to Diesel Conversion and they say their mounts move the motor as far back as you can go before hitting the firewall (1" clearance). With the cab off tough to verify, anybody out there use their mounts?
If I can't move the motor back I'm left with question on whether to modify the driveshaft or convert to slip yoke. From what I read fixed yoke is stronger and has less vibration.
Another thought I have is to make a 3" spacer that bolts between the driveshaft and fixed yoke.
Another photo.
Last edited by claybreaker 144; Feb 17, 2014 at 07:08 PM. Reason: Automerged Doublepost
Old Feb 20, 2014 | 11:41 PM
u2slow's Avatar
I would find a different shaft to shorten, or re-tube the one you have. Losing the fixed yoke would be a mistake IMO.
What about moving the steady bearing mount forward? Is there extra travel in the rear slip yoke? Are you upgrading to bigger rear axle with a longer pinion? Just some ideas to consider....
Old Feb 21, 2014 | 01:34 PM
Looks like I can only pick up a 1\2" moving the steady bearing closer. I am going to make a coupling to connect the fixed yoke and driveshaft. If that doesn't work it will cost $150 to get the driveshaft lengthened and balanced. Not planning on any rear end upgrades.
Old Feb 21, 2014 | 02:03 PM
biged681985's Avatar
i would get it lengthened. i wouldnt chance it breaking and messing up the tcase
Old Feb 21, 2014 | 10:27 PM
u2slow's Avatar
The guys at dieselpower did a little firewall mod to get the engine back a bit.
Custom Firewall Fill Plate Photo 10
Reason I asked about the rear diff.... the Dana 80 has a ~2" longer snout than a D70. I can only imagine the Ford 10.25" similar to the D70 in that respect.
Old Feb 26, 2014 | 11:48 AM
oldmansimek's Avatar
Go get your driveshaft lengthened! Or call up someplace like Tom Woods custom driveshafts and have them make you one. I wouldnt start moving your motor back until you get the cab on, but I still doubt you will be able to move it enough to use that shaft and still have travel.
DieselDan370
Aug 23, 2016 02:24 PM
STDiesel59
Jul 11, 2015 10:09 AM
F250MACH
Apr 26, 2015 05:19 PM
mcclusk
Feb 21, 2015 09:50 PM
Ryans71
Nov 28, 2014 09:46 PM
