OD light blinking
Old Feb 12, 2014 | 06:06 AM
daves93f250's Avatar
Default OD light blinking
My od light is blinking I know its reading a code, but how can i know what code. So is there a code reader for this truck cause ive been looking and i haven't found anything.
Old Feb 12, 2014 | 11:40 PM
Dortiz's Avatar
Usually when the O/D light flashes and gives a weird shift/jerk, it's either the tach sensor, or speed sensor. Could be many other things, but those are the 2 most common.
Check your transmission fluid, If it feels tacky, REPLACE THE FLUID, or if it smells burnt and is dark in color, it should never be sticky/tacky, I would replace it as soon as possible
Old Feb 13, 2014 | 12:36 AM
powerstrokin350's Avatar
I can't remember, but can you " jump " the two diagnostic ports like on GM OBD II systems to get codes to blink at you?
Old Feb 14, 2014 | 07:43 PM
4x4manonbroke's Avatar
Buy a 4spd and junk the slush box...... been there done that ..... love the 4 spd
Old Feb 18, 2014 | 01:52 PM
ALWAYSREADYROB's Avatar
Default OD Light
Also check the gear oil in the rear Differential...I had the same thing happen so I DC the battery to reset it and it would act fine for about 20 min then light comes on...truck starts fish biting....I finally checked the gear oil and it was 1 + qt low...filled it up and it stopped. !
Old Feb 18, 2014 | 05:44 PM
dieselram94's Avatar
This is not a good sign...been there done that. Has the trans been hot?
Sent from my USCC-C6721 using Tapatalk
Old Feb 18, 2014 | 08:23 PM
can you check for line pressure and when was the last time you had the pan off and did the filter replacment and service to the trans ..... band adjustmets could be off and trans is warning you of a issue ..
low line pressure would be a place to start....
Old Feb 23, 2014 | 10:13 AM
Found out it was the TPS sensor. It was really corroted and dirty, cleaned it and it stopped blinking, but I replaced the sensor anyways and it runs again. And now at least I know what can cause my o/d to blink. Thanks guys.
Old Mar 16, 2014 | 02:30 PM
Is there a website where I can purchase a Fill Tube for my 97 turbo E4OD Trans?
Ford does not stock the part anymore, am I off to Pick a Part for this one?
I still have the tube and its not leaking but I cannot find a bracket to stabilize it up top...its zip tied for now.
Old Mar 16, 2014 | 03:22 PM
Dortiz's Avatar
I used to know a site that had all of them, I'll look for it tonight
