twin turbo'd 12v
Old Feb 11, 2014 | 07:49 PM
khturbo96's Avatar
Default twin turbo'd 12v
so I am new, and I was curious what y'alls opinion was.. for a 12v twin set up, would you prefer s475-hx45 or your own opinion of your choice? I will be pulling sled and I will have a 215 with 5x25s possibly.
Old Feb 11, 2014 | 08:21 PM
12vcummins96's Avatar
welcome to the site
go to our cummins section and ask people will have great insight
i have a compound set up and your injectors are way to large for the set up you are talking about
Old Feb 11, 2014 | 08:44 PM
khturbo96's Avatar
Im wantin to use 5x25s, but I also want twins. Single turbo I was thinking gt42 but like I said I want compound turbos. What did youhave in mind..turbo wise for those injectors
My boyfriend has a 98.5 12v with 215, gt42, 5x25s, no plate, SB dd, and extreme custom cut pistons, he loves his injectors but i dont want the same exact set up.. thats the reason for my twins im hoping. and would 5x16s or 5x14s work well with my set up? Really hoping for a set up for 5x25s, HELP PLEASE!!
Old Feb 11, 2014 | 08:54 PM
are you going to pull in the open class
with that small of a primary i wouldnt recommend anything over a 5x16
if you go with a gt4202 with a 1.1 turbine housing and mods to help it spool a set of 5x20s would be ok
but as for compounds the turbos will have to be fairly large to run that large of an injector
Old Feb 11, 2014 | 09:00 PM
khturbo96's Avatar
Yes and ill be takin chances at 2.5 and ws do you have any suggestions turbo wise for larger injectors
Old Feb 11, 2014 | 09:06 PM
for compounds you could run a 63/68 .83 over a 83mm or bigger to run over a 5x18s or nothing larger than a 5x22
what mods are you going to do to the engine to aide in your power quest
Old Feb 11, 2014 | 09:22 PM
khturbo96's Avatar
That part im still unsure..
Why are there so many running 5x14s with 62/68 ? Is the 62/68 really reliable
Old Feb 11, 2014 | 09:33 PM
It is a really good well rounded turbo
Old Feb 12, 2014 | 03:43 AM
97cummins's Avatar
Old Feb 12, 2014 | 09:17 AM
khturbo96's Avatar
the more fuel the better really. so if i use big injectors and a nice sized turbo/twins i need all the hp i can get, and i appreciate all the opinions and suggestions but i dont live by the book
