Power Guess
Old Feb 6, 2014 | 12:41 AM
12vcumminspower7's Avatar
Default Power Guess
I was thinking about throwing my truck up on the dyno,but first i thought maybe someone here could give me a close estimate to RWHP?
*4in downpipe to 5in
*#100 plate all the way forward and afc housing
*injen cold air intake
*40hp sticks
*pushing about 33-35 psi boost
*aFe intake manifold
*pump is pretty much maxed out
Any numbers would be greatly appreciated,just thought i would ask on here first
Old Feb 6, 2014 | 05:22 AM
turbo2332's Avatar
235.4hp
521 tq
Old Feb 6, 2014 | 11:06 AM
Originally Posted by turbo2332
235.4hp
521 tq
Wow,Thought i would have been a little closer too 300 but Thank You!
It gotta be a little higher cause its only a bed length behind my sons 2004 LB7,Which has like 315?
Old Feb 6, 2014 | 11:48 AM
94 12valve's Avatar
250ish if your trans is fresh
Old Feb 6, 2014 | 11:52 AM
What else do i need to get somewhere around 300-350?
Where would if i threw some 70-90 instead of 40?
Old Feb 6, 2014 | 01:08 PM
94 12valve's Avatar
for 300 to 350 you will need more timing, gov springs, mod your wastegate and a trans that will hold it.
On a side note your pump is no where near maxed out
Old Feb 6, 2014 | 01:14 PM
What timing?16*?4,000 GSK or 3,000?And what do you mean mod my wastegate?I dont want to put anymore than 35psi on my stock turbo?I have a bighead wastegate and a boost elbow?
Would i be closer to 300 if i threw 70-90HP sticks instead of 40?
Old Feb 6, 2014 | 01:35 PM
cummins_guy's Avatar
just because they (pro-noun people) are claiming 40 hp injectors, does not mean 40hp
and you asked a loaded question.
I would put it on a dyno and then come back with numbers and then we could sit down and really help you.
with what you have posted, I have seen numbers as low as 250 and as high as 350.
all depends on if it is set up right.
Old Feb 6, 2014 | 01:44 PM
Alright,Thank You,and i understand that it doesn't mean "40hp" and these injectors are only 4 hole and didn't see much performance only 1-2 MPG increase,so i was thinking maybe a 70-90 would maybe wake her up a lil
Old Feb 6, 2014 | 05:15 PM
JBearSVT's Avatar
Why don't you want to push more than 35psi with the stock turbo? I realize it isn't particularly efficient up there, but I regularly bury the needle on my 40psi gauge with my stocker with no issues?
