1994 12valve auto trans problems.
Old Feb 3, 2014 | 04:02 PM
Cumminsman911's Avatar
Default 1994 12valve auto trans problems.
I have a 94 12 valve auto. it will shift fine to third then the trans temp light will come on and never shift to 4th and over drive then the light will go off and it will shift up. Then randomly come back and down shift to third. Fluid is fine. Any help would be great!
Old Feb 3, 2014 | 06:22 PM
Diesel Duo's Avatar
Sounds like your transmission temperature sensor.
Does it make a difference if your truck is cold or warm?
DD
12vcumminspower7's Avatar
Possibly TPS?Just look at some more threads,somewhere on here someone has had the same or similar problem
Old Feb 3, 2014 | 08:34 PM
4x4manonbroke's Avatar
could also be a plugged cooler/heat exchanger ..... might wanna trouble shoot more ... possible flow issue ...
Old Feb 3, 2014 | 09:59 PM
How would i go about troubleshooting the cooler?
Old Feb 4, 2014 | 06:59 PM
akcoalroller's Avatar
need to see if any fluid is getting through the cooler. not sure what the pressure should be through it but it might be a good idea to change the filter and get some new fluid in there, make sure nothing is clogged up. have you pulled the pan since this started happening?
Old Feb 6, 2014 | 04:44 PM
Fluid is alright, it was a bad trans temp sensor.
Old Feb 6, 2014 | 09:29 PM
as i figured ... something silly
Old Feb 6, 2014 | 09:35 PM
Heck yea! That's good! Cheap easy fix!
Sent from my GT-I9300 using Tapatalk
Old Feb 7, 2014 | 11:53 AM
Heck yea, 25 bucks and like 5 minutes took longer to crawl under and back out of the truck than it was to put it in!
