Help! fuel pressure problem
Old Feb 1, 2014 | 03:07 PM
js2c's Avatar
Default Help! fuel pressure problem
I installed my fuel pressure gauge into the side of the fuel pressure regulator where there was a shrader valve to test pressure. so the gauge wasn't reading anything so I bought a fuel pressure tester and hooked it up. I read 0 psi with key on and 10 psi with truck running. I guess you can shim the spring but if it is my lift pump how do you test that? I thought I read it should have 50 psi. any thoughts or tests that I can run myself?
Dbleo351
Nov 20, 2016 09:34 AM
stevew970
Jeep Liberty
Aug 31, 2015 07:56 AM
ctjkelley
Jun 3, 2015 06:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
