OM617 Swap into 97 Jeep Wrangler
Old Jan 31, 2014 | 04:58 PM
neomagnus2's Avatar
Default OM617 Swap into 97 Jeep Wrangler
This is my first diesel swap, EVER. I expect to get alot of headaches and frustration... so i hope i get alot of help from you guys
my plan was to gather all the necessary stuff for the swap before starting
So far....
Engine (82k miles original), Turbo , Fuel Pump, Original Engine Harness (Fully Intact), MB Power steering pump, MB A/C Compressor, MB Glow Plug Relay, A-MB208 Adapter Kit (from Mercedesdiesel4x4), MB113 Exhaust Kit (also from mercedesdiesel4x4)
What i need to get....
Need to convert my gas tank to a diesel tank (must flush and clean) for the conversion i was thinking of using the Fuel Pump conversion for the jdjeepstore, or should i use my current fuel lines? <------------- Room for Suggestions
Jeff Daniels Jeep Customization
I need to fabricate motor mounts because apparently the ones they have at mercedesdiesel4x4 dont fit my model without "Major modification"
if anyone knows anywhere else where i could buy this, it would help alot, or atleast a picture of what the fabrication of my mount should look like... Maybe measurements... mhmmm...
A-MB106 Motor Mounts
Alternator Preferably one that fits on the MB alternator bracket, i read that the 60v alternators blow... and that i should aim for a 150v...
If im missing any items please feel free to post under i appreciate all the help i can get, though i am a novice, im very passionate about this project and my jeep
I can also use help on any diagrams of wiring the engine harness to my current jeep harness
Look foward to help and criticism!
Old Feb 5, 2014 | 12:43 PM
neomagnus2's Avatar
The Work place
Old Feb 5, 2014 | 12:44 PM
neomagnus2's Avatar
Some pics of the jeep
Attached Thumbnails OM617 Swap into 97 Jeep Wrangler-jeep1.jpg   OM617 Swap into 97 Jeep Wrangler-jeep4.jpg
Old Feb 5, 2014 | 12:48 PM
neomagnus2's Avatar
the dismantling begins
Old Feb 26, 2014 | 11:45 AM
oldmansimek's Avatar
Is the motor a 617 or a 617A? will make a big difference if you are looking to make some extra power.
Old Mar 20, 2014 | 12:54 PM
Markdiesel's Avatar
just getting started on the same swap. Just finished pulling everything out of my wrangler last night. Got to get rid of the old V8 and auto transmission so I got room to work in the garage. How's your project coming along?
Old Mar 30, 2014 | 05:12 PM
redveloce's Avatar
Let me know if you guys need any help with the TJ electronics. I know them top to bottom. There's no reason to rip out the stock cluster, it's actually pretty easy!
Sent from my Nexus 7 using Tapatalk
Old Apr 3, 2014 | 12:07 PM
Alexgardner's Avatar
That'd be sweet!
Old Apr 7, 2014 | 11:34 AM
atrussell129's Avatar
I'm doing the same swap but I'm stuck on the motor mounts. If anyone could post pictures of their mounts to help give me an idea that would be awesome. (1997 jeep wrangler 4 cylinder)
Old Jul 26, 2014 | 01:15 PM
neomagnus2's Avatar
Sorry guys havent been on in a long time real busy, even fell behind on my project >.>
its coming along nicely, got my engine in the car believe its a 617a
as for the mounts its pretty tough to say, i cut off the old mounts and reused them, some people reuse the MB motormounts but i made my own, ive seen some use old chevy rocker mounts. but i think reusing the old mounts is the best cost efficient way to go.
Working on converting my gas tank and i should be done with my build, just gotta do the a/c later on, but i just want it running with the top off :P
