A cummins I finally found...
Old Jan 31, 2014 | 03:24 PM
bod925's Avatar
Default A cummins I finally found...
Hey I am a newbie in the diesel world trying to learn as much as I can through research but I have found a truck I really like and I have a few questions, first here is the CL ad:
03 dodge cummins h.o. 6 speed, 145,000 miles, 4x4 works great. Leveled, 20x9 fuel hostage wheels wrapped in 35 inch nitto trail grapplers with 90 percent tread left. Great running truck.
Here is a few extras:
64mm silver bullet turbo
Banks high ram
Smarty TNT tuned
Fass fuel system
Valiar single disc clutch
Intake
5 inch straight Mbrp exhaust
7 inch tip
3 pod gauges
19-24mpg
http://images.craigslist.org/00a0a_e...qn_600x450.jpg
I will not be racing or towing with this truck. Its going to be my "weekend" truck and will be driven maybe 7-8k miles per year.
My Questions:
1. The seller said his diesel mechanic recommended but said its not necessary, but getting 100hp nozzles (not injectors) would help the it run smoother because it is getting an unbalanced amount of air compared to fuel. Does this sound correct? Any damage that could have occured up to this point from to much air? i.e. high egt's?
If I do decide to do that, is it wise to go with nozzles or should I go all the way with injectors? I think all I can afford would be the nozzles unless I wait a year.
2. Most 6speed trucks I've found have Southbend Dual clutch installed. How does this Valiar clutch compare? Better, worse, same?
3. He says the Fass Fuel is annoyingly noisy until you get used to it. Is this normal?
4. I don't know anything about turbos...is this a good one to have?
THANKS!
Old Feb 3, 2014 | 06:55 PM
36valves's Avatar
Truck looks nice. How much?
Old Feb 19, 2014 | 02:39 AM
1stGenForTheWin's Avatar
Yea, price is going to play a key role in my decision to track this truck down and buy it out from under you.
Let's see, a 03 5.9 Manual trans all black Cummins...modded...and only 145k miles? Friend, this is my holy grail. UNLESS he's asking $32k like all the other Craigslist douchecanoe's.
JoeyMiR
9
Feb 3, 2018 10:05 PM
Dstrachan5
Jun 16, 2015 04:10 PM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
