88 f250 hard to turn ignition when cold
Old Jan 30, 2014 | 01:55 PM
Crazyredneck1980's Avatar
Default 88 f250 hard to turn ignition when cold
Is there anything I can do to fix it.its really hard to turn when it's cold outside.also one other question why does my fuel guage go to full when I only put 5 or 10 gallons in the tank. could it be a bad float. THANKS FOR ANY INFO
Old Jan 30, 2014 | 02:35 PM
CARP's Avatar
Take apart the steering column and grease the ignition. Stock gauges will be like that. They are not the best….
Old Jan 30, 2014 | 02:52 PM
4x4manonbroke's Avatar
the switch on the bottom of the steering column is most likely to blame ... they become incrusted with dirt internally ...
If this keeps up .. you will break the cam inside behind the tumbler and its not fun to do .... the rod runs from back of tumbler to the switch on column .. if it does break you can use a small pry bar claw foot to push it down towards floorboard and it will turn over .. i had to break the cover off ... was in a hurry and late for work ...
Now i have a simple push button for starter and the rest still works fine ... just wont push starting rod all the way down .. and now i can crawl over rocks ..
klein444
Jun 20, 2015 11:48 PM
91 7three
Jan 7, 2015 09:37 AM
