03 Duramax: one cylinder seems to hit hard and smoke
Old Jan 26, 2014 | 12:07 PM
IHdude's Avatar
Default 03 Duramax: one cylinder seems to hit hard and smoke
Hi i have an 03 duramax that is all stock except a straight pipe. Driving down the road today it started smoking quite a bit and sounded like one cylinder was getting overfueled. Any ideas on what test? Its not throwing a code either.
Thanks for any help!
From some of the reading I have done I'm thinking it could be a stuck injector? I don't have a way of confirming it tho?
Old Jan 26, 2014 | 06:16 PM
elivingston's Avatar
Crank and let run turn it off and pull glowplugs. The wet one will be the injector to replace.
Old Jan 31, 2014 | 09:02 AM
jkidd's Avatar
check contributions with a scan tool.
If you pull the injector we can test it on our common rail bench.
Timglow546
8
Jun 3, 2015 10:13 PM
gator515
Jan 14, 2015 01:56 PM
