Valve spring question
Old Jan 25, 2014 | 03:28 PM
Kbnecessary's Avatar
Default Valve spring question
Can u change the valve sping by rollin piston to top of each cylinder or do u have to pressurize it wanted to do it without pullin injectors since im getting another set next month
Old Jan 25, 2014 | 03:31 PM
mysterync's Avatar
Don't think I would feel comfortable trying that. Pulling injectors will happen regardless if you end dropping a valve.
Sent from my SCH-I605 using Tapatalk 2
Old Jan 25, 2014 | 03:42 PM
turbo2332's Avatar
absolutely you can. @ tdc the valve will fall 1/8 of an inch maybe? have a magnet on the stem as you remove the keepers just so you have a hold of things if you arnt right on the money. installation of the new springs is tricky if the piston isnt all the way to the top because you have to smash the new spring farther to get the retainer and keepers back on. be careful, watch your valves as you roll the engine over and it will go fine.
Old Jan 26, 2014 | 09:37 AM
Thx man thats what i was thinkin didnt want to do the injectors twice but i dont wanna wait to put the valve springs since im doin governor springs now
51Hudson
55
Jul 8, 2018 08:17 AM
oneloud59
May 16, 2015 10:00 AM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
