Lift, Suspension, Tires
Old Jan 23, 2014 | 04:12 PM
Cummins_Power_13's Avatar
Default Lift, Suspension, Tires
Hey, I'm looking to have a wider stance for my truck. I want the tires to stick out 2-3" from the side of my truck. What do I need to do in order to achieve this? How big of a lift can I get away with to maintain this? Thanks for the help!
Old Jan 23, 2014 | 04:52 PM
turbo2332's Avatar
i will sell you my 33x15.5x16's they are wide. LOL i had to level the fron trim the cab and weld knuckle stops to run this wide of a tire and not rub.
Old Jan 23, 2014 | 05:05 PM
JBearSVT's Avatar
That sounds like the tire he'd need to stick out that far too, unless he changes rims for a different backspacing/offset.
Old Jan 26, 2014 | 08:35 PM
Did you have a lift with these tires you have? And I do want different rims than what I have now.
Old Jan 26, 2014 | 08:37 PM
turbo2332's Avatar
2" front leveling bushings and the above modifications.
Old Jan 26, 2014 | 08:52 PM
So if I were to put a 4" lift, I probably wouldn't have to worry about rubbing?
My current tires are 285/75R16. What would be the best for a wider width?
Last edited by Cummins_Power_13; Jan 26, 2014 at 08:52 PM. Reason: Automerged Doublepost
Old Jan 26, 2014 | 11:54 PM
Cjasso78's Avatar
With a 4" lift you would have no problems rubbing 33's, but it would look funny. You would want to bump up to a 35" tire if you want to lift it 4". That is my 2 cents
Old Jan 27, 2014 | 05:54 AM
turbo2332's Avatar
yes your truck would look ridiculous with 33's and 4 inches of lift.
going wide has many draw backs
Old Jan 27, 2014 | 11:07 AM
Yeah, I was actually looking at getting 35's with a 3-4" lift.
And will bigger tires fit my rims I have now? Or will have to get bigger rims as well?
Last edited by Cummins_Power_13; Jan 27, 2014 at 11:07 AM. Reason: Automerged Doublepost
Old Jan 27, 2014 | 05:07 PM
turbo2332's Avatar
what size wheel do you have? a 8-10'' wide wheel looks good with a 12.50
