Fuel adjustment
Old Jan 17, 2014 | 04:47 PM
powerstrokin350's Avatar
Default Fuel adjustment
Was curious what y'all thought about this adjustment, does it add power?
Old Jan 18, 2014 | 09:17 AM
Dortiz's Avatar
I've heard about it, but have yet to test it out, Nor do I really want to, for me it just seems to good to be true not to mention easy haha
Old Jan 19, 2014 | 05:46 PM
bigjohn's Avatar
I would like to hear more about it
Old Jan 19, 2014 | 11:41 PM
I though I've heard it would make you smoke by adding fuel, but wouldn't add power like adjusting the other screw through the window on the side. But wouldn't adding fuel no matter how, increase power, in a diesel that's pretty much all you need is fuel and air, right?
I was a little curious about another trick I heard of on FB. Some old truckers were talking about how they used to get a little more power out of their big rigs by putting vice grips on their fuel return lines. But had to make sure it wasn't too tight otherwise the engine wouldn't come back down to idle very well. I though "damn that be some back woods *** way to getting more power". One feller said he'd done it and had some real dark coal rolling out.
Old Jan 20, 2014 | 12:06 AM
Dortiz's Avatar
Well there's only one way to find out if the stories are true haha, try it and let me know how it rolls
Old Jan 20, 2014 | 02:52 AM
I don't know about the vice grips one, but I am going to try the other bolt adjustment. Just a bit leery since I don't have a pyro yet. Figure I could use it like my '03, as long as I don't use it too much or long I should be ok.
Old Jan 20, 2014 | 05:00 AM
bigjohn's Avatar
I mite try that torque screw but if no one else has done it I'm not sure I want be number 1
Old Jan 20, 2014 | 07:17 PM
4x4manonbroke's Avatar
Its Bound to be true ... when you choke off the return line you end up with more residual pressure @ return lines and more left in the injection lines ... more pressure means more pressure @ injector and probably a better spray pattern ... on my Cummins we change the orfice sizes on out return lines and they run much better like that ....
WARNING: by doing this you may fry your IP ... not enough flow to keep it well cooled and you may suffer unwanted conciquences .... You have been warned
Old Jan 20, 2014 | 07:44 PM
Dortiz's Avatar
That's what I was thinking, main reason why I won't try until someone has data with a long trial and effects of the mod
Old Jan 21, 2014 | 06:20 PM
bigjohn's Avatar
i tryed this today with no real change in anything i also checked the net and found a few other posts on this but it had no effect on my truck as best i could tell whent back to stock seting
