12 valve Excursion, ex. manifold questions
Old Jan 10, 2014 | 11:11 AM
Buckshot927tx's Avatar
Default 12 valve Excursion, ex. manifold questions
The exhaust manifold on the 1st gen Cummins puts the turbo too close for comfort to the fan box. I can see it over heated or melting it being a possiblity. Fordcummins sells a manifold that puts the turbo down below and out of the way. I dont want to spend the $400 they want for the manifold if i dont have to. Is there a cheaper way? Maybe a second or third gen manifold? Lemme know, thanks
Old Jan 10, 2014 | 12:59 PM
u2slow's Avatar
The 2nd-gen manifold is the the same. The 3rd-gen has a an offset outlet - although offset to the rear. It can be flipped to get the turbo forward, if you have enough hood clearance.
Old Jan 10, 2014 | 08:29 PM
deck60's Avatar
check on the manifolds from I think an 05 is what I used
Old Jan 10, 2014 | 09:32 PM
Alrighty i'll check on that and get back with ya, thanks alot man.
FarmDiesel
Ford Excursion 99-05 7.3L and 6.0L
Feb 1, 2016 11:38 PM
Jake12valve
May 10, 2015 11:57 PM
LTreis702
Feb 14, 2015 12:52 PM
12&24 Valve cummins
Nov 13, 2014 11:05 PM
Nov 12, 2014 08:10 AM
