LMM Performance Discussion of Chevy and GMC Trucks with LMM Duramax Turbo Diesel Engines Related To Performance And Longevity
Limp Mode With No Codes
Old Apr 17, 2008 | 10:13 PM
TEXASPOWER's Avatar
Default Limp Mode With No Codes
ive got limp mode with no codes the only thing i can think off iss the dpf has been off with no prob and the quad with no codes now to night we got lots of rain the only thing i can think of is the sensor wires (conections) got wet there zip tied up but do u think being wet would affect them
Old Apr 17, 2008 | 10:31 PM
TCU Fan's Avatar
Aaron
I go into limp mode on the highway sometimes with no codes either. I never drive the truck hard but sometimes when the truck shifts from 6 to 5 or 4 to pass or go around someone it does it.
I have not tried to take the PPE out to see if it will still do it.
Old Apr 17, 2008 | 10:35 PM
TEXASPOWER's Avatar
well mines doin it constantly evenidling, it needs and oil change can them oil changy magiger sensor thing make it go into limp mode
Old Apr 17, 2008 | 10:37 PM
TCU Fan's Avatar
Aaron
I am not sure, I have changed my filter 3 times with just over 15k on it so it would not seem like that would be the cause.
Old Apr 17, 2008 | 10:40 PM
DangerousDuramax's Avatar
Is it limping the engine or tranny? Sounds like your getting a "tie-up". Change your filter first and see if it improves.
Old Apr 17, 2008 | 10:44 PM
TEXASPOWER's Avatar
i guess the engine i can lear it and somtimes it will take 5 min to come back on and some time 30 sec, it fell like it just wont run like it would yesterday i thought fuel filter but (already went through that ) but no codes maybe ill get the wife to get both changed 2morrow
Old Apr 17, 2008 | 10:49 PM
TCU Fan's Avatar
Aaron
I usually just pull over, turn the truck off for 30 seconds and then it runs like normal. Now that I am thinking about it, mine did it before I got my PPE put on and I did that at around 1,200 miles.
I may not be tuner related.
Old Apr 17, 2008 | 10:55 PM
TEXASPOWER's Avatar
mines prob driver related wife drives it with no problems but wen i do somthing always happens , it just makes me mad no code is through i gues ill just hold it to the floor wile keep clearin it and melt it down , i guess i might have to put the dpf back on and take it in, one thing also it used to not smoke with dpf but right before i took it off it smoke quite a bit with it on it might be broke too
Old Apr 17, 2008 | 11:05 PM
If it limits you to 2000 RPM's its an engine limp. If it downshifts and locks into 3rd gear its a tranny limp. Its not unusual for it not to throw a code when you're running programmers or anything that can defeat what the ECM see's.
Old Apr 17, 2008 | 11:11 PM
TEXASPOWER's Avatar
engine limp then i ve already had egr prob and miilions of times my dpf has cloged , i just hope it aint nothin real bad , but i guess you gotta pay to play exspecially if u got a new engine with a new product hackin things off and knw body realy knows if it really works or not yet
