Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
Differentials And Trans
Old Apr 17, 2008 | 08:06 PM
solarwarp's Avatar
Arrow Differentials And Trans
When, for my 07 Dodge 5.9, am I supposed to change the front and rear diffs. I have automatic transmission, when should that be changed too?
I think I want to change the diffs to Amsoil.
Old Apr 18, 2008 | 02:02 AM
01quadcab's Avatar
check the owners manual it gives recomendations. But if you want to change to amsoil just do and get it done. Never hurts to have good clean oil in the diffs. the trans I was told to change every 15k but everyone has their own ideas
Old Apr 18, 2008 | 05:51 AM
Heath's Avatar
Authorized Amsoil Dealer
Many change those diffs at 5000 or so to get that breakin material out. The tranny can wait, 20-30k is a good range, unless you want to get the synthetic in there.
Old Apr 21, 2008 | 12:13 PM
06Dodge's Avatar
For 2006 it was 15K for the diff's and 30K for the trans and trans filter. If you run Amsoil SVG gear oil in the diff's you can go a lot longer then 15K. If you also use Amsoil ATF then after 2, 30K changes you could extend it to 50K or more.
Old Apr 24, 2008 | 09:41 PM
solarwarp's Avatar
I want to change out my differentials to Amsoil... which weight oil should I get?
Mostly daily driver town/hiway, tow loads occasionally short 50-75 mile runs. Putt around ranch in 4hi mode occasionally.
Old Apr 24, 2008 | 10:00 PM
Marine's Avatar
I use 75-110 Amsoil in the diffs and Amsoil ATF in trans. I do trans at 30k. front diff about 30k and rear about 20k.
Old Apr 25, 2008 | 05:54 AM
Heath's Avatar
The 75W-90 will work great for both diffs. Some, like Marine, use the 110 in the rear for just a little added "cushion" for towing. Can't go wrong with either.
maverick52
Recreation Vehicles (RV's)
Aug 25, 2015 10:50 PM
