325/70r17
Old Dec 30, 2013 | 08:40 PM
Kbnecessary's Avatar
Default 325/70r17
would these fit on the back of my dually with a set of 2 in spacers found a awesome deal on them and thought they would be cool if theyd work I don't tow heavy very often so has anyone tried this
Old Dec 30, 2013 | 09:32 PM
six speed's Avatar
i think these should be about 12.79 inches wide and almost 35 inches tall. i don't think they will fit with 2 inch spacers. i have a friend running 285s with 2 inch spacers and their about as wide as you could get to fit it think.
Old Dec 31, 2013 | 03:48 PM
4x4manonbroke's Avatar
you could just go single rear wheel with them until u tow ... then change tires .... thats my plan ... 18's for haulin *** and 265/75/16's for haul grass ....
Old Jan 2, 2014 | 10:26 AM
I just got a set of 285/70r17
Old Jan 5, 2014 | 03:13 PM
Borrowman32's Avatar
I have a 94 regular cab dually. 4 in lift and i am running 315 70 16. with a 1 3/4 spacer. But when put on a load my tires touch so i need to go to 2 in spacer. Also remember Stock rims are 6.5 in wide. i have had balancing issues. balancing beads seem to work better then wheel weights on this setup.
How did your 16.5 timing help your mpgs. hows your cold weather starting. my timing is 13.5 I think that's stock and I only get 11 mpg. thinking about changing it to help mpgs
Last edited by Borrowman32; Jan 5, 2014 at 03:13 PM. Reason: Automerged Doublepost
