cracked 7.3 powerstroke engine block
Old Dec 27, 2013 | 01:48 PM
fordpowerstroke1995's Avatar
Default cracked 7.3 powerstroke engine block
i have a 1996 7.3 powerstroke engine setting in my garage. i just pulled it from the wrecked truck about a month ago. right directly above the starter it has a hairline crack about half the length of the engine. it drips coolant pretty bad. i tried some stopleak in it before i pulled it from the truck and that didn't work so i was wandering if i could get y'alls input on what i could do without having to weld the block
Old Dec 27, 2013 | 01:57 PM
joebob3093's Avatar
Moderator
I would scrap it
Old Dec 27, 2013 | 06:28 PM
Bigg Redd's Avatar
Trash it bro.
Old Dec 27, 2013 | 07:20 PM
i probably will. it has a borgwarner s475 turbo on it so i am going to take that off of it and the starter alternator and the a/c compressor and then haul it to the scrap yard
Old Dec 27, 2013 | 07:32 PM
joebob3093's Avatar
Moderator
What are you doing with the 475 and mount? Any other performance mods ?
Sent from my KFSOWI using Tapatalk
Old Dec 27, 2013 | 07:37 PM
forgot to mention the stage 3 rosewoods and the dual terminator hpop's. i will probably install these things on my 1995 f250
i wish that there where someway for me to fix the engine man i hate to scrap it cause it ran fantastic. last time it was dyno'd it had around 480hp/906ftlb
Last edited by fordpowerstroke1995; Dec 27, 2013 at 07:37 PM. Reason: Automerged Doublepost
Old Dec 27, 2013 | 08:18 PM
joebob3093's Avatar
Moderator
Numbers sound a little low for the mods, what size stage 3s?
Old Dec 28, 2013 | 02:46 AM
yep rosewood stage 3's. and yes when i had it dyno'd i also thought it was pretty low for the mods it had. i figured it would be alot higher than that
Old Dec 28, 2013 | 03:29 AM
joebob3093's Avatar
Moderator
Stage 3 means nothing, are they 238s with a 80 or 100% nozzle or are they 250s with 100 or 200% nozzles? Makes a huge difference and an S475 is a huge turbo to be running as a single if your DDing it
Old Dec 28, 2013 | 07:55 AM
Slim Whitey's Avatar
My advice to you is to take it to an engine/machine shop with it completely stripped down, and cleaned up. And be prepared to hear 1 of 2 answers:
1: Nothin we can do.
2: well, it ain't gonna be cheap. . .
