Audio Equipment/Electrical Discussions Based on Automotive Stereo Equipment Such As Amps , Head Units & Speakers Including Installation and System Set Up Information. Electrical or wiring issues on anything that requires wiring.
HELP: Starter shorting out
Old Dec 16, 2013 | 08:13 AM
strokinit91's Avatar
Default HELP: Starter shorting out
2001 f250 7.3....Sitting in line at the drive-thru the radio shut off, headlights dimmed/flickered, and I noticed a burning smell. Shut the truck off, and found the starter had shorted out. This was a 100% new bosch starter installed less than 2 weeks ago. I had the truck towed to a mechanic who installed a 100% new motorcraft starter, that one shorted out on the first turn of the key. Has anyone else run into this problem? / How did you fix it? The truck is now at a different mechanic b/c the first said he wouldnt be able to fix it, is there anything quick I should check for that could be causing this issue while I am there this afternoon? I am located in Morgantown, WV.
Old Dec 17, 2013 | 05:21 PM
Solved...it was a bad relay
leocanuck
6.0L Performance
Sep 27, 2015 06:05 PM
klein444
Jun 20, 2015 11:48 PM
james2562
Feb 5, 2015 09:05 PM
nevadagramm
Oct 17, 2014 07:59 PM
thunderball52
Oct 6, 2014 08:08 PM
