Power estimate
Old Dec 12, 2013 | 04:16 AM
nonricer's Avatar
Default Power estimate
Hey guys im new here.
My plans are to convert a 5.9 into an 84 gmc jimmy.
Anyway the question I was going to ask was how much power and torque would be made with this setup and also would it be suitable for a daily driver ok the parts are all brand new and are as follows
98 12 valve Cummins 5.9
Apr headstuds 247-4205
Hamilton 165# valve springs
Hardened con rods
Milled intake
Ported cylinder heads
Runner style intake manifold
Gorilla girdle
Apr mainstuds and conrod bolts
220-240-108 csa cast cam .385/.385
Flycut pistons
Phatshaft 62 turbo
Borgwarner s474
Also does anyone know where you can get an intercooler to fit the jimmy
Thankyou your replies are much appreciated
Old Dec 12, 2013 | 11:23 AM
94 12valve's Avatar
line bore the cam install bushings and run a steel cam. Zach makes great cams but for that size IMO steel is the way to go.
What kind of power are you lookin to make?
Old Dec 12, 2013 | 08:57 PM
4x4manonbroke's Avatar
what injectors you planning on running ??? and .. DD ? sounds like your gonna need a good trans for all that ...
5x14's ... my estimate .. 500 all day 1250 tq... all guestimate ... of course if the trans/clutch will hook it up ..
Old Dec 13, 2013 | 11:20 AM
94 12valve's Avatar
Hardened con rods
Milled intake
Gorilla girdle
Flycut pistons
Phatshaft 62 turbo
Borgwarner s474
For 500 hp you don't need anything in red would be a huge waste of money. before the op starts buying parts they need to come up with a power goal. Just buying parts because there the biggest is not the best choice
Old Dec 13, 2013 | 01:11 PM
Rx7man's Avatar
I would be starting to worry a lot about how that jimmy will hold the weight of that engine, and how the trans and diffs will put up with it... a stock 5.9 governor springs, fuel plate, and with a 60mm HX35 will have the ***** to break most ordinary tranny, tcases and diffs... I hope you have plans on putting a bigger diffs in that thing!
Old Dec 13, 2013 | 07:19 PM
nonricer's Avatar
Ok so what are the limits of a 14 bolt diff and a dana 60 and the trans I was looking at is a gm 4l85e from gearstar which cab hold 1200 hp and 1000 lbft
Old Dec 15, 2013 | 03:55 AM
nonricer's Avatar
Also would you be able to square off the chassis
What would be the actual limiting factors im hoping for at least 400 hp and at least 500 lbft as a minimum thanks
Also I think I should upgrade the suspension from a larger model
But if I can get more power reliably then that would be the go
Also needs to be good for a daily driver runnig a tranny that can handle 1000 lbft and a 14 bolt in the rear and a dana 60 in the front
Old Dec 15, 2013 | 09:18 AM
94 12valve's Avatar
Apr headstuds 12mm
63/68/14 charger
good intake and 4" exhaust
Air dogg 150 with 40psi spring
5x.014's
#10 plate
Modded afc
Rack plug
4k springs
timing to 18*- 20*
This is all you really need for a healthy 400hp the rest of your list is extreme overkill for that power number
Old Dec 15, 2013 | 09:39 AM
illinoisfox's Avatar
Your torque numbers will be twice the HP numbers! That is what we love with the Cummins 12 valve motors.
Old Dec 15, 2013 | 05:45 PM
94 12valve's Avatar
We love them ... but that 14 bolt won't
