Cold start or long crank problem
Old Dec 10, 2013 | 08:27 PM
Fynn's dad's Avatar
Default Cold start or long crank problem
Hello all I am completely new to posting but I have been reading for a month or so. I will post as much information as I can recall.
The problem is that the 2004 ram 3500 cummins will not start below 65 degrees unless the block heater is plugged in or I hit it with ether. Once it has started it will run great until it has sat long enough to cold soak. I have ran thro the air intake heater troubleshooting and even replaced the temp sensor. I have tricked the relay with a 9v battery and it still will not start. I have change fuel filters, air filters and both batteries.
I recently took it to a local diesel shop because I started to loose faith in my own troubleshooting. I informed them of all of my previous efforts. I asked that they look into the lift pump. The shop said this was not my problem. They requested that I approve $450 in additional troubleshooting to check the fuel injectors. I do understand that a small crack in an injector(s) could cause the fuel to bleed back and prevent me from getting the required pressure (5K psi I believe). So I took the truck back and started looking for tests I can run myself.
I have ordered the Miller line block tool. Having read many other post and talking with a person at Geno's garage my understanding is that I can block each (excuse my terminology if it is incorrect)output line on the common rail 1 at a time. My understanding is that if I block one off and I am able to start the truck it mean that the associated injector is cracked for worn.
My question is: Do I simply leave the fuel feed line to the injector disconnected with the output on the common rail pugged when I try and start the truck? Will this cause any damage? Can the fuel pressure back feed through the injector to the loose line? Am I missing anything?
If I find a back injector it is my intent to R&R it myself... Any thought?
One other pertinent fact about my fuel system is that I run aircraft fuel (jet a or the MIL cert version JP-8) I add stanodyne for additional lube.
Any help is greatly appreciated
Couple additional notes
5.9L cummins
I live in Denver and the problem started in September at elk camp I did have to replace a surp belt that was coming apart at that time. Also I am at 137k miles. No mods other than the 5th wheel towing package.
Last edited by Fynn's dad; Dec 10, 2013 at 08:27 PM. Reason: Automerged Doublepost
ish1521
Aug 26, 2015 08:42 PM
dandbmcc
Mar 14, 2015 11:05 PM
ajs93hd
Feb 25, 2015 09:28 AM
custom7.3
Nov 23, 2014 10:44 PM
weatherby
99-03 7.3L Performance
Nov 5, 2014 10:45 PM
