1999 cummins 24v fuel system parts
Old Dec 7, 2013 | 07:45 AM
nwright002's Avatar
Default 1999 cummins 24v fuel system parts
Hey guys I have some parts that I no longer need since I upgraded to an airdog 150.
1- raptor 100 lift pump with wiring harness. $175 obo
2- fuel filter housings.
1 housing has a hairline crack in it
1 lid leaks slightly around where the fuel preheater wires com in the top
1 housing is free from defect
1 lid is free from defects but will need a plug in it where the fuel preheater wires come in because it is an open hole right now.
1 factory fuel line from the filter housing to the vp44.
make me an offer on the filter parts either each piece or everything.
thanks for looking. I can be contacted at 740 627 1500 and ask for Nathan. Either text or call if i dont answer i will get back to you as soon as I can.
Old Dec 9, 2013 | 12:47 PM
98cummins's Avatar
is the raptor 100 a good upgrade from the stock pump? I have a stock pump and all I keep reading is I should replace it. Thanks
Old Dec 9, 2013 | 06:43 PM
nwright002's Avatar
the fuel pressure is adjustable so yes it is.. i had it adjusted at 21-22psi at idle and it was around 15 at wide open throttle.
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
