injector fuel caps
Old Dec 5, 2013 | 10:51 PM
iditexaswelder's Avatar
Default injector fuel caps
My injector fuel caps are leaking on the passenger side just replaced lines orings and washers. I also tried putting washers on top of the caps but still seeping between the cap and injector. Running out of options
Old Dec 5, 2013 | 11:16 PM
Dortiz's Avatar
Did you lube the orings before you placed the caps
Old Dec 5, 2013 | 11:25 PM
No I didn't is it too late? I bought the kit from pensacola diesel not sure how good is was going to be. but by the looks they are not that good.
Old Dec 6, 2013 | 07:22 PM
Dortiz's Avatar
Putting them on dry like that will cause them to tear, and as far as the quality, I wouldn't use the orings that come with any of the kits haha, always use a high quality brand when I use new ones.
Old Dec 7, 2013 | 02:08 PM
4x4manonbroke's Avatar
go to a hydraulic shop and get the new O-rings .. use motor oil and lube the junk out of them .. and the inside of the cap too .. they go together real nice that way .. i also use a Cigar cutter for the lines .. real nice cuts and its easy to replace ... mine is plastic with a angle blade... think i spent a whopping 1.99 for it...... .... (insert smart *** CRS comment here).
