5.9L12valve Cummins defective fuel filters
Old Nov 16, 2013 | 02:58 PM
59skippy's Avatar
Default 5.9L12valve Cummins defective fuel filters
I have recently had a series of fuel filter and fuel sensor failures on brand new parts both OEM and after market. Including the gasket blowing, Fuel sensor O-ring failure and leakage, and the most recent is the fuel sensor screw housing on the fuel filter cracking and dumping 30 gallons of diesel out on the road in little over 100 miles.
Has any one had any problems with filters recently?
Old Nov 16, 2013 | 05:33 PM
JBearSVT's Avatar
I've never had a leak from a sensor failure. I have had a few fuel filter gaskets fail (three Fleetgaurd and one Napa), but I never lost 30 gallons before figuring it out. I left a three foot wide trail of fuel through four towns one day, and it cost me five gallons. Oh- that particular time was when the bolt that holds the housing together broke. Easy fix at the nearest hardware store. I suggest anyone still running the stock filter setup get a spare of that bolt and keep it in the truck. I've heard that the filter housing is known to crack though, although I've never actually seen it.
Old Nov 16, 2013 | 06:06 PM
59skippy's Avatar
It was after dark and I was doing 80mph down the highway. I did not look in my rear view much. When I did roll to a stop some one pulled up and said they saw from behind. If you are in town driving it is very apparent. I had a Mopar filter fail the gasket blew out of the housing. At high way speeds it is tougher. Any suggestions on what parts perform best?
Old Nov 16, 2013 | 07:58 PM
JBearSVT's Avatar
I haven't been let down by Wix yet.
I only found out about my leak when I went to make a right turn and the *** slid out from the rear tires rolling through my own spill. Ended up cinching the housing together with a ratchet strap to get back to the shop...
Old Feb 12, 2014 | 05:41 PM
akcoalroller's Avatar
I have always just run the "high end" wix filters. never had an issue with them whatsoever.
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
Collin Dow
Feb 21, 2015 08:18 PM
moneypitk5
Feb 12, 2015 11:01 AM
