fuel rail issue
Old Nov 16, 2013 | 12:29 PM
wrenchin's Avatar
Default fuel rail issue
guys I have a 2007.5 dodge with full delete kit and H&S tuner, truck has run great since I did the deletes two months ago. Today I finally got around to installing my fuel rail shim kit, I put the shim kit in and now the truck wont start. I also updated the tuner for the higher pressure setting. I am guessing the issue is that air got into the fuel rail when I took the relief valve out. How do I bleed it? Will it work its way out if I keep cranking it over? do I need to crack the lines to the injectors and have some one crank it to purge the air? I am guessing there is a simple fix here, problem is I dont know what it is..... any help greatly appreciated.
Dbleo351
Nov 20, 2016 09:34 AM
Cavnar
Sep 9, 2015 07:18 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
