97 powerstroke exaust
hi i just bought a 97 f350 powerstroke,i noticed that the exaust leakes on both sides between the manifold and the up pipes.Can i use a exaust doughnut and change the studs that fasten them,up pipes look good thx
whats another option for up pipes if not thx
I am pretty pleased with the Diamondeye exhaust products I have found...you may want the check out their items if you have to replace something. Still mandrel bends and stainless but not quite as pricey as the big guys...
one more thing when the truck is cold it souds like air spraying loud,havent had someone around to help,but the leak on both sides is bad is it possible when the wastegate open its sucking air in thru the leak,seems to be power loss too,weird def sounds like its coming from the gaskets from inside the truck
