white smoke at start up and blue driving
Old Oct 26, 2013 | 10:14 AM
jimmyjamjam's Avatar
Default white smoke at start up and blue driving
I am going to look at an lb7 duramax in a few hours does anyone know or have any ideas what would cause this the check engine light is on also and codes say cylinder misfire I'm OK with it being injectors or head gasket I don't want to buy it if its low compression due to rings it has 198400 miles thanks for your response
Old Oct 26, 2013 | 05:59 PM
Walker.B's Avatar
to me it kinda sounds like injectors but I'm not sure if bad injectors would cause a miss fire maybe ones stuck closed or an computer/electrical issue. anyway I had a simulator experience with my dads truck long story short it became a no start.
Old Oct 26, 2013 | 06:10 PM
What do you mean a no start
Old Oct 26, 2013 | 10:31 PM
Walker.B's Avatar
we didnt run the truck for about 6 months i got in it it fired up and by the time my hand was on the shifter it died and hasnt ran since then my dad gave it to me im replacing the injectors now. what happend is the fuel seprated when it didnt run for so long and the injectors rusted inside they were already going out and as soon as it ran long enough for the rust to hit the seat and ball in the injectors it killed all 8. if you can be sure its injectors you can replace them for around $2,000 if you do be sure to get good ones dont go cheep youll regret it fast i would put a better fuel filter on to if i were you this is what ill be running after im done replacing my injectors i bought the 1 micron filter. if that truck has the stock injectors in it they are probably ready to be ret
Billet Aluminum OEM Filter Adapter, Nicktane
