Starting Issues and Fuel Gauge Issues (1998 Cummins 24V)
Old Oct 24, 2013 | 10:53 PM
Lanceomni's Avatar
Default Starting Issues and Fuel Gauge Issues (1998 Cummins 24V)
1998 24v
Fuel gauge goes from full to empty every minute or so. Was able to make three trips since it started. Assuming it was the sending unit.
Last two trips:
Started cold in the morning with no problems.
Got fuel. Warm start no problem.
Returned to vehicle, cost start wouldn't turn over.
It took about 5 tries to get it to start and then it works fine.
History immediately prior to issue
After sitting for a few weeks, I noticed that someone had likely siphoned fuel but couldn't get the cap back on (installed bed. Cap binds and is tricky to get in). So its likely that the truck sat for some time with a loose cap. Could the lack of a seal caused pressure to drop and build up on components?
Earlier this year
A gear within the starter broke teeth. Replaced and had no problems.
01trailerpuller
Jul 28, 2017 01:10 AM
Powerstroke36
Sep 21, 2015 08:32 PM
gauge1325
May 3, 2015 01:33 PM
J. Nick
Apr 25, 2015 05:01 PM
Collin Dow
Feb 21, 2015 08:18 PM
